Counter/Timer
markwysong - 6602 counter help
thanks again for your help. yes, i do have analog outputs. I think I will simply use those to make TTL pulses.
(3,919 Views)
I think it would be easiest with it. Simply set up a buffer containing two values, 5 and 0, and output that at 200 samples a second, triggering on your input signal. Easy enough.
Mark
(3,919 Views)
