Home
Community
Discussion Forums
Most Active Hardware Boards
Counter/Timer
Topic
Counter/Timer
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
markwysong - 6602 counter help
Jay Gibson
Member
06-05-2001
03:16 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
thanks again for your help. yes, i do have analog outputs. I think I will simply use those to make TTL pulses.
0
Kudos
Message
1
of 2
(3,916 Views)
Reply
Re: markwysong - 6602 counter help
markwysong
Active Participant
06-05-2001
03:25 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I think it would be easiest with it. Simply set up a buffer containing two values, 5 and 0, and output that at 200 samples a second, triggering on your input signal. Easy enough.
Mark
0
Kudos
Message
2
of 2
(3,916 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
