Counter/Timer
output one voltage at every coming external clock rising edge
Hi,all.
    I wrote the attached code to output voltages triggered by an external clock.The external clock is about 1 Hz.For examle,I want to output 256 different voltages and change the voltage value when a new coming rising edge is ditected.
    The problem is when I run the code it says there is no data in the output buffer.
    Can anyone help me out with this puzzle?
帖子被jyp在04-16-2008 01:02 AM时编辑过了
帖子被jyp在04-16-2008 01:04 AM时编辑过了
(3,349 Views)
Duplicate post !
(3,336 Views)
