DASYLab
Control Simulation within DasyLab
I want to build a control simulation circuit within Dasylab. So  I use several modules like filters and math-modules to describe my control circuit.
To close the control circuit I have to connect the Output of the last modul to one input of the PID-Modul.
But that generates an error. How can I achieve a closed loop ?
(7,661 Views)
Andreas,
To loop back, you need to insert a Time Delay module, and check the Enable Signal Loops setting.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,626 Views)
