DASYLab
How do I implement a 16-bit encoder?
I need to read 16 TTL outputs and determine the value of 16 parallel bits and make a decision from that value. How do I do that? Would this be done using a Black Box?
(7,444 Views)
Accepted by Williamx
There is a Mathematics Group module called Bit Mask that will allow you to combine the 16 digital channels into a single word -- and then be able to read it as a single value.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,438 Views)
Excellant CJ! Thanks very much again for your help!
(7,430 Views)
Sorry CJ, I jumped to the conclusion that I could implement my "16-bit in to integer out" converter with the Bit Mask module, but I don't understand how the integer output is presented and what special settings I need to make internally to the module settings to get it to do this. Can you give me some more details?
Bill
(7,428 Views)
Here's an example. It's V11.
I used a Switch module to simulate the TTL channels -- then used the Combine/Extract Bits mode of the Bit Mask module. The  output value is displayed as an integer, and then I used a mode of the digital meter to display the binary and a mode of the Status Lamp to display the bits.
(7,426 Views)
