DASYLab
dasylab
Does any body knows how to migrate an application written in Dasylab 8.0 to LabVIEW 7.0? It would be kindly appreciate it a step by step process, thanks!
(8,547 Views)
edwardo,
What is the DASYLab program doing?  Is it communicating with a DAQ card.  Some details would be helpful since the steps you would need to take would vary depending on what you wanted to do in the program.  There is a migration tool available for download, but you may still need to do some adapting.  I would check out the help files for this tool for instructions on how to use it.  Please let me know if you have any questions.
Thanks!
Andy F.
(8,535 Views)
DasyLab is hooked up and running to the computer and accesories (cards, etc). I do need to use LabVIEW since we have the program here atthe university and we do not hav DasyLab. Therefore I need to either create a nw program using LabVIEW or migrate the existing one Dasylab to LabVIEW. Anyway I do not know much about LabVIEW either. I can send you the Daysylab program is needed. I downloaded the program migration of Dasylab to LabVIEW.
Edwardo
(8,533 Views)
There is no direct way to move a DASYLab application to LabVIEW. As the Migration Guide will have explained, all we can do is tell you the equivalent LabVIEW functions. Since it was written several years ago, it does not discuss any of the newer features of LabVIEW, especially the Express VIs.
Fundamentally, you have to recreate your application. You should probably just create it from scratch, taking advantage of the full features of LabVIEW, rather than trying to re-create the exact way it was done in DASYLab.
Sorry that we cannot be more help.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,519 Views)
