DASYLab
power density spectrum
I am using strain gage accelerometers to collect X, Y and Z axis acceleration data on separate channels as a means of quantifying vibration in the cab of an off-road motor vehicle.  Using the DASYLab "formula module" I have scaled the output of the accelerometers to read directly in gs, i.e. 32 ft/s/s = 1 g.
If I use the DASYLab "fft module" to provide a power density spectrum for a g vs time waveform generated by one of my accelerometers, what are the y scale units that are delivered by the "Y/t chart module"?  I know the x scale units in the chart are Hz.
I am trying to produce a data display figure that has the same format as power spectral density data presented in the figures in Mil-Std-810G Method 514.6 Annex C.  That document presents sprectral data in the form of curves of (g^2)/Hz vs frequency.
So far none of the data I've collected in my vehicle, looks anything like the data shown in the in the mil spec.
(9,482 Views)
you would like generate this type of visualization?
20703iD45CF97C8435C0EB
MHa
(9,474 Views)
Here is an example of the type of figure I'm trying to generate from X (longitudinal), Y(transverse) and Z(vertcal) accelerometer data.  I have client who wants to use accelerometers to make physical measurements of the vibrations in the cab of an off road vehicle, and my client wants the data I collect protrayed in the same form as the following chart which comes from the mil spec.  The figure below is an example from the mil spec  The data I have is X, Y, and Z acceleration vs. time data.  I'm looking for the tool or method or combination of tools and methods that will get me from the data I have to a chart like the one shown below.
20737i1A5598DC5C528674
(9,469 Views)
Hi edfritsch,
I was wondering what hardware you were using to take these measurements in DASYLab. Could you please let us know?
Rohan B
(9,444 Views)
I've used an Iotech DAQBOOK/200 connected to the Dell computer through a network connection to manage data collection.  An Iotech DBK 43A amplifier conditioned signals from my three accelerometers (3 separate Sensotec 060-F482-0).
I’ve logged data at 2000 samples/sec and 5000 sample/sec with similar results.  Data logging was accomplished using DASYLab 8.0 data acquisition software.
I'm still looking for an answer to my original question which was "What are the Y-axis units on the power spectral density plot that the DASYLab FFT module produces?"
(9,440 Views)
When you select the Power Density Spectrum function in the FFT (Real FFT of a Real Signal), the Unit changes to (#0 * #0) / Hz
This notation means that it will take the incoming unit, noted as #0, and the outgoing unit is that unit squared / Hz.
If the incoming unit is g, then g^2/Hz is the unit of the computed signal.
You can get DASYLab to display the unit, by going to the Y/t Chart Display window, select the Display menu, Window, Display Y Unit.
20953i65FB4AE7E957F32F20955iA2ADDD5EFD9E6E99
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(9,418 Views)
Accepted by edfritsch
Thank you for reading the question I asked, considering it and answering that question instead of going on about some other marginally related topic. I sincerely appreciate your knowledge and your willingness to share it.
(9,413 Views)
