DIAdem
Accessing GPIB through Diadem Script
Do I need Diadem DAC to access the script functions for GPIB?  I don't need the visual layout of DAC, I can write code for it all, but I don't know the commands to use.
Thanks.
(5,929 Views)
Hello RusselSenior,
yes you can access GPIB and other interfaces in DIAdem without DAC.
There is only a description available how to use the UDI control in DIAdem DAC, but it works in normal scripts as well.
DIAdem UDI Control
In chapter 4 you find a description of the syntax of this UDI control.
(5,910 Views)
