DIAdem
Average of a channel based on conditions of 2 other channels
Hi all,
I'm looking to include in my script the calculation of the average of a channel (sys_power) based on conditions of 2 other channels (engine_RPM & comp_temperature). I am setting the engine conditions at [795 < RPM < 805], and [-21 < T < -19].
Whenever these conditions are met, I would like to take the values of sys_power at these conditions, and take an average.
I've been playing around with a few functions, such as ChnEventStatArithMean and For loops, but to no success so far! Any help appreciated.
Andrew
(3,788 Views)
You will find a very detailed example already installed with DIAdem called "Test Rig Analysis".
It basically includes everything you need to get mean values for specific channel events:
http://zone.ni.com/reference/en-XX/help/370858M-01/exploff/examples/expl_valve_analysis/
As this is very detailed, I created a more simple example for you based on the DIAdem example_data.tdm file.
It should be ready for direct use:
dim i, MeanVals()
call Data.Root.Clear()
call DataFileLoad(ProgramDrv & "Examples\Data\example_data.tdm")
'find all events for speed between 20 and 100
ChnEventList1 = ChnEventDetectionWindow( , "[1]/Speed", 20, 100, 0, 0)
'find all events for Revs between 4500 and 5000
ChnEventList2 = ChnEventDetectionWindow( , "[1]/Revs", 4500, 5000, 0, 0)
'combine events with logical AND
ChnEventResultList = ChnEventOperationAND(ChnEventList1, ChnEventList2)
'resize array for mean values
redim MeanVals(ubound(ChnEventResultList,1))
'calculate mean values for all events
for i=0 to ubound(ChnEventResultList,1)
	MeanVals(i) = ChnEventStatArithMean("[1]/Torque",ChnEventResultList,i)
	call LogfileWrite(MeanVals(i))
next
In DIAdem 2017 this will become more easy as you can directly select characteristic values in the analysis dialog:
Regards
Christian
CLA, CTA, CLED
(3,774 Views)
Hi Christian, that's great thanks.
One final question, instead of showing the Mean Values in the log file, its more use to me if I write them to a channel. What is the best way of doing that?
Andrew
(3,744 Views)
Accepted by andrew88
Here's one possible way:
dim i, oMeanChn
'create channel for mean valuen
set oMeanChn = Data.Root.ChannelGroups(1).Channels.Add("Mean Values", DataTypeChnFloat64)
    oMeanChn(i+1) = ChnEventStatArithMean("[1]/Torque",ChnEventResultList,i)
next
Christian
CLA, CTA, CLED
(3,742 Views)
Hi Christian,
That's great, I've just tested it with my script and it works perfectly.
Many thanks for your help,
Andrew
(3,728 Views)
