DIAdem
C# wrapper error code 6211
I am writing a wrapper in C# to read TDM files too.
But I met the error code 6211 using OpenFileEx.
using System.Runtime.InteropServices;
namespace MyTDMSTest_CSharp
   class Program
        [DllImport("nilibddc.dll")]
        static extern int DDC_OpenFileEx(string filePath, string filetype, int readOnly, out IntPtr pfile);
        static extern string DDC_CloseFile(out IntPtr pfile);
        static extern string DDC_GetLibraryErrorDescription(int errorCode);
        private const string FILE_PATH = "testtdms.tdms";
       static void Main(string[] args)
            int ret;
            IntPtr pfile;
            ret = DDC_OpenFileEx(FILE_PATH, "TDMS", 1, out pfile);
            if (ret < 0)
               string buff = DDC_GetLibraryErrorDescription(ret);
               Console.WriteLine("\nError:{0:D} {1}",ret,buff);
               Console.ReadKey();
            else
               DDC_CloseFile(out pfile);
This code shows bellow message.
"Error:-6211 The storage could not be opened."
I'm using VS2010 with Win7(32bit) .
How to solve this error?
Thanks for any help.
(4,632 Views)
I have no real knowledge about C wrapper in c# but I assume string does not work.
I think there must be some kind of Marshaller.
[MarshalAs(UnmanagedType.LPStr)]string filepath
because you have to convert to char*.
(4,606 Views)
Hello Andreask
Thank you for your quick reply.
I have modifed the code.
            [MarshalAs(UnmanagedType.LPStr)]string filePath,
            [MarshalAs(UnmanagedType.LPStr)]string filetype,
            int readOnly,
            out IntPtr pfile);
But that does not work . it shows the same error.
I guess the error code 6211 is caused by pfile because i got other error  "Error:-6209 The file passed to the library does not exist." when i changed the FILEPATH.
Best regards
(4,600 Views)
Accepted by Takayama
In case you have copied the dlls to a different location, did you also copy the "DataModels" folder?
(4,589 Views)
Smiley Very Happy
Thank a lot. It is solved !!
   class Program
        static extern int DDC_CloseFile(IntPtr pfile);
        static extern int DDC_GetFileStringPropertyLength(IntPtr pfile, string property, out int length);
        static extern int DDC_GetFileProperty(
                IntPtr pfile,
                string property,
                StringBuilder fileproperty,
                int valueSizeInBytes);
        private const string FILE_PATH = "TdmsSampleData.tdms";
            int ret;
            IntPtr pfile;
            int length;
            if (ret < 0) return;
            ret = DDC_GetFileStringPropertyLength(pfile, "name", out length);
            if (ret >= 0)
                StringBuilder buff = new StringBuilder(length);
                ret = DDC_GetFileProperty(pfile, "name", buff, length);
                if (ret < 0)
                    string msg = DDC_GetLibraryErrorDescription(ret);
                    Console.WriteLine("\nError:{0:D} {1}", ret, msg);
                    Console.ReadKey();
                else
                    Console.WriteLine("File name property ({0:D}): {1}", length, buff);
                    Console.WriteLine("End of program, press Enter key to quit");
                    Console.ReadLine();
            ret = DDC_CloseFile(pfile);
(4,578 Views)
