DIAdem
Calculate an isoline surface in a characteristic diagram
Hi, I would like to calculate the surface of isolines in a characteristic diagram that I generate in DIADEM, is it possible?
I use the characteristic diagram to generate an effeciency mapping of an electric motor (the isolines represente levels of efficiency) and I would like to know the surface under my boundary curve occupied by the isolines 80% and higher.
Thanks for your help.
(5,284 Views)
Hi TM4_essais,
Please have look at the example "Contour Display in DIAdem VIEW". It seems that it shows what you are requesting.
Greetings
Walter
(5,264 Views)
