DIAdem
Replacement of numeric values with strings in TDMS
Hey guys,
does the TDMS file format offer the possibility to assign different strings to specific values of a channel?
I'd like to store channels with numeric values and replace some of them with strings. So I don't want to store them as strings directly. A simple example would be a digital channel, where I want to store 0 and 1 as integer values and replace them with “low” and “high”, when interpreting the data e.g. with DIAdem.
I didn't find any property or something else in the documentation, so I don't know if it is possible at all.
Thanks in advance
Cynthia
(4,925 Views)
There is a DIAdem example:
2D Axis System with Text from a Text Channel
doing something like this. But I assume the text is stored in an additional channel.
(4,915 Views)
