DIAdem
Channel is out of data matrix
Hello:
My question is about DAC and NI-Max. when i run script in DIAdem, it warned:"U30 channel is out of data matrix."The detailed information are attached below as pictures.
Do you met the same problem? could you give me some suggestion? Thanks in advance.
(3,471 Views)
Hi DinaDing,
What is the command in line 252 of your script "ak-stand.vbs"?
Greetings
Walter
(3,454 Views)
Hello  Walter:
The content of the wrong code are:a=Find("ch(L4)>=0.5")  ------242 line.
You can get the logic of these codes below in the picture.
Dina Ding
(3,444 Views)
Hi Dina Ding,
L4 should contain the channel number of the channel with name "I30". Does this channel exist? What is the content of L4?
Greetings
Walter
(3,442 Views)
Hello Walter:
L4=CNO("I30"), L5=CNO("U30"). I also defined I30 and U30 in DAC. You can see the DAC information in the picture.
(3,426 Views)
Hello Dina Ding,
Yes, I understand. My questions are:
1) Do those channel exist and appier in the Dataportal?
2) What is the content of L4 and L5? (you can display that for example with the command MsgBox)
Greetings
Walter
(3,424 Views)
Accepted by DinaDing
Hello Walter:
I think i solved this problem just now.
The reason caused this warning is that:
The wrong trigger setting in DAC block leaded data-acquisition can't work.
Thanks for your reply.
Dina Ding
(3,420 Views)
