DIAdem
Controlling Report Legend with Script
I've using the curve related text option of the Legend in my report. Is there a way to modify this with a script?
(3,663 Views)
Accepted by TamerA
Hi TammerDTS,
These properties are part of the curve settings:
dim oCurves
set oCurves = Report.Sheets(1).Objects("2D-Axis1").Curves2D
oCurves(1).RelatedLegendText(1)  = "atest"
oCurves(2).RelatedLegendText(1)  = "btest"
Greetings
Walter
(3,634 Views)
Thanks again Walter, works great. I had a little trouble trying to figure out what the 2D axis system was named, but I figured it out by deleting it, then the confirmation message told me the name.
(3,626 Views)
In case it helps anyone, I created a loop to modify multiple channels on all my sheets.
Option Explicit
Dim oCurves, iLoop
For iLoop = 2 to 27
	Set oCurves = Report.Sheets(iLoop).Objects(1).Curves2D
	oCurves(1).RelatedLegendText(1)  = "Channel 1"
	oCurves(4).RelatedLegendText(1)  = "Channel 4"
	oCurves(7).RelatedLegendText(1)  = "Channel 7"
	oCurves(10).RelatedLegendText(1)  = "Channel 10"
(3,621 Views)
