DIAdem
Data Plug In needed for NHTSA crash test data format EV5
I was hoping some one could make or link me to a Data Plug In for this type of data:
The link to the site is here:http://www-nrd.nhtsa.dot.gov/database/aspx/vehdb/testtabledetails.aspx?LJC=7481&existphoto=Y&p_tstno...
Thanks alot,
Message 1 of 11
(7,710 Views)
Accepted by Wormspur
Hello Wormspur,
I have attached a beta version of our NHTSA EV5 DataPlugin for you.
To install:
  1. Please unzip the attached ZIP file
  2. Double click on the "NHTSA_EV5.uri"
  3. The DataPlugin will be installed and report success
  4. Open DIAdem and you should be able to use EV5 files just like any other DIAdem supported DIAdem data file format
If you have any feedback on this DataPlugin, it would be very appreciated.
     Otmar
Otmar D. Foehner
Message 2 of 11
(7,706 Views)
This is what I needed.  Thanks Otmar!
--matt
Message 3 of 11
(7,697 Views)
This plug-in used to work for me.  Now it does not.  It could be a DIAdem 2010 to 2011 thing.
Can someone please look into it for me.
The advantage of the EV5 over the UDS is that with EV5 all channels are loaded in one group.
Thanks for your help.
--matt
Message 4 of 11
(7,461 Views)
Hi Matt,
The Data plugin that you are currently using is EV5,  correct? Are you wondering why the UDS Dataplugin no longer works properly? Please let me know which one you would rather use and why?
Perry S.
Applications Engineer
Message 5 of 11
(7,446 Views)
Brad sent me the official NHTSA version.  I guess the goverment took over the plugin.
I have attached the latest version.
--matt
Message 6 of 11
(7,438 Views)
Ever since I upgraded to DIAdem 2012, this EV5 DataPlugin no longer works.  I modified the script to output a log file, and it completes loading all of the channels and properties, but then stops and DIAdem becomes unresponsive.
Any ideas what's going on here?  Is there something that needs to be changed about the DataPlugin (written for DIAdem 2011) to be compatible with 2012?
Thanks...
Message 7 of 11
(7,237 Views)
Hi pcloadletter,
The EV5 DataPlugin works fine for me when I use it in DIAdem 2012 on a test file I happen to have handy.  Could you submit or email me (brad.turpin@ni.com) the data file you're failing to load?
Brad Turpin
Message 8 of 11
(7,220 Views)
Is there any way that I can convert a .dat data set into an .EV5 data set.  I have the .EV5 plugin and I can import .EV5 data sets, however, I would like save a file from .dat to .EV5.
thanks
Message 9 of 11
(6,828 Views)
Hello Mike,
The EV5 DataPlugin is read-only, so there is currently no way to crate an EV5 file from DIAdem.
    Otmar
Otmar D. Foehner
Message 10 of 11
(6,822 Views)
