10-15-2009 02:55 AM
I will disturb you with a short question, maybe easy for you but I didn't find a solution for my self ( I'm a novice in working with Diadem DAC)
I build a scheme and when I run it I receive an error ( see attachment) "...invalid mathematical operation" and I don't know what is wrong.
Maybe I don't know how to work with the formula block, and maybe you can give me some hints.
Please have a look on this error (see attachment) and tell me what to do.
Solved! Go to Solution.
10-15-2009 03:28 AM
Hy again,
I came back with some auxiliary info.
I have seen that I need to use auxiliary variables, but I have 40 variables ( channels that I want to use in formula blocks) , and I can't assign all as auxiliary variables.
How to declare the all 40 channels?
10-16-2009 03:53 AM
Try formula without the ' character like this Resistor100_1tens / 100
If you need 40 channels in one calculation then you need to divide the fomula into multiple formulas, each formula block can have max 10 channels.
10-16-2009 03:55 AM
Hi Marse,
It seems that you're using DIAdem 10.2. In this version there was a limit for the symbol name in the f(x) block of 16 characters. If you change the name it works fine (please have a look at the attachment). This is changed with DIAdem 11.0 or later.
Referring to your second question I'm not such whether I really understand the problem. Please can you explain what you would like to do?
Greetings
Walter
10-16-2009 03:57 AM
10-19-2009 10:07 AM
Hello Walter,
Referring to the second question, I was thinking to transform all the 40 channels to auxiliary variables, so the formula can work, but I find out later that if I will change the name of the channels( to be shorter) it will work.
In Diadem 11 you don't have a limit of characters?
Thank you again for your help.
Marius
11-02-2009 12:57 AM
Hi Marse,
Sorry for the late response, but the last two weeks I wasn't in the office. Yes, since DIAdem 11.0 we don't have a channel name length limitation.
Greetings
Walter
