DIAdem
Editing the right click context menu
Is there any way to customize/ alter the buttons that pop up when you right click on a channel in the data portal. Specifically adding custom functions such as invert or other mathematical functions?
(3,048 Views)
Hi BrandonHosken,
The context menu in the dataportal is adjusted to the current mouse position. This means that it will compile the content dynamically. For this reason, it is not possible to customize this context menu except to add custom menu items at the bottom. Here is an example:
Call AddUserCommandToEvent("Portal.Events.OnShowingContextMenu","MyPortalOnShowingContextMenu")
Call AddUserCommandToEvent("Portal.Events.OnContextMenuPointSelected","MyPortalOnContextMenuPointSelected")
Sub MyPortalOnShowingContextMenu(ParentObj, MenuPoints)
  If (ParentObj.IsKindOf(ePortalList)) Then
    Call MenuPoints.Add("My Portal List Menu", 1)
  End If
  If (ParentObj.IsKindOf(ePortalStructure)) Then
    Call MenuPoints.Add("My Portal Structure Menu", 2)
  End If
End Sub
Sub MyPortalOnContextMenuPointSelected(ParentObj, MenuPoint)
  Select Case MenuPoint.ID
    Case 1    Call MsgBoxDisp("DIAdem-Portal: My List Menu selected")
    Case 2    Call MsgBoxDisp("DIAdem-Portal: My Structure Menu selected")
  End Select
End Sub
Greetings
Walter
(2,954 Views)
This code runs successfully in the scripting tab, but I dont see anything change when right clicking on the data portal, is there a further step I need to do to make this work as intended? Thank you for you help!
(2,942 Views)
Oh, sorry I have forgotten to mention that you need to save the code as file and register the file as user command.
Greetings
Walter
(2,936 Views)
Yes it worked when I did that thank you very much! Is there any way to get the list of channels that are currently highlighted in the data portal?
(2,930 Views)
Accepted by BrandonHosken
Here is an example:
  End If
    Call MenuPoints.Add("Add <_Test> to channel name Menu", 2)
  End If
End Sub
    Case 2    Call DoSomeThing
  End Select
End Sub
sub DoSomeThing
  dim oChn
  if Portal.Structure.Selection.Item(1).IsKindOf(eDataChannel) then
    set oChn = Data.GetChannel(Portal.Structure.Selection.Item(1).GetReference(eReferenceDefault))
    oChn.Name = oChn.Name & "_Test"
  end if
end sub
Greetings
Walter
(2,914 Views)
Thank you so much for the help! I appreciate it!
(2,906 Views)
