DIAdem
Error ModName: msvcr80.dll
When I try to run a script in DIAdem that was working three days ago, the program shuts down without an error warning. When you click to on the extra info of the windows error reporting, it gives the following information:
AppName: diadem.exe AppVer: 10.2.0.3031 ModName: msvcr80.dll
ModVer: 8.0.50727.762 Offset: 00045c6f
Does anyone know what this means or how to stop DIAdem from closing when I run the script?
(6,360 Views)
Hi, HockeyDude,
Several questions for you:
1) What operating system are you using?
2) It looks like you're using DIAdem 10.2, is that correct?
3) What does the script do? Is that the only script causing the problem or other scripts do the same thing.
4) I noticed you posted a similar post earlier, is that the same issue?
Song Du
Song Du
Systems Software
National Instruments R&D
(6,334 Views)
Hi, Song,
Thanks for replying. I am using Windows XP on a dell system. I am using DIAdem 10.2. Every script that use to execute for me does this problem, even when I write new scripts the same problem happens. The earlier post was about the same issue.
(6,325 Views)
Thank you for your help. I figured the problem out. Not sure what it was, but I just rewrote the whole entire thing letter by letter and it worked. Some odd reason a new exact copy works.
(6,309 Views)
Hi Hockeydude,
would it be possible to get a copy of the script which caused the problem ? R&D would like to find out what the root cause for the problem was.
Andreas
(6,286 Views)
