DIAdem
Error
Accepted by say12
In Report module under Settings --> Layout Setup --> Layout Parameters --> Master Layout --> activate automatically refresh...
or set this variable
Report.Settings.MasterLayout.UseCheckForNewVersionOnLoad = True
Regards
Christian
CLA, CTA, CLED
Message 11 of 13
(1,322 Views)
Thank you so much cristian !
Regards
Message 12 of 13
(1,316 Views)
Hi say,
When you associate the master layout with the TDR file, the dialog that you do that in has a checkbox that says "Automatically refresh master layout when loading the layout".  Please check that checkbox and resave the TDR file.  Now every time you load the TDR file it will look for the TDRM file on disk and reload it and remerge it with the TDR file contents.  This is what I tested on my end with the code I sent.  You will need to change the font size logic so it never goes negative on your end.
Brad Turpin
Message 13 of 13
(1,304 Views)
