DIAdem
Excel File modifying
I created an Excel file wich I use as a template for some data analysis reports. I'd like to use DIAdem to change values in this file and to save it, but without changing the original file design.
I already tried to save as a CSV, but of course the special fonts and colors I used are not supported. A TDM doesn't fit eather.
For information, I know I could do such things directly in DIAdem Reports, but the result wasn't completly what I expected, and I want to export Excel files to allow people without DIAdem to modify the values if necessary.
I join the Excel template I want to modify with DIAdem, to make it clear.
I hope I am clear and somebody has an idea to solve this question.
Thanks for help.
(3,500 Views)
Accepted by Romain.P
If Excel is installed you can use its OLE interface to write new data to your file.
Here's a simple example:
dim oExcel,oWS
'get excel automation object and open workbook / -sheet
set oExcel = CreateObject("Excel.Application")
call oExcel.Workbooks.Open(CurrentScriptPath & "Report Template.xlsx")
set oWS = oExcel.Worksheets(1)
'change your data here using line and column index for your cells
oWS.Cells(3,3).Value = 11
'save file and close Excel
call oExcel.ActiveWorkbook.Save()
call oExcel.Quit()
set oExcel = nothing
Also have a look at this DIAdem example: DIAdem Client Operation with Excel as Server
Regards
Christian
CLA, CTA, CLED
(3,452 Views)
