DIAdem
Exporting with DataFileSaveSel and setting ASCIIREALFORMAT in 10.2
Just downloaded and started evaluating DIAdem 10.2 last night. Scripts that are working in 10.1 are now broken in 10.2. The "datasavesel" function returns the error "the configured header number must be >= then channel number" in 10.2. I tried converting the code to use the DataFileSaveSel command but this function appears to ignore the values set in the ASCIIREALFORMAT variable. The number formats are customer defined and cannot be changed. How do I export text files with explicitly defined number formats for data channels in 10.2?
Thanx,
Bill Davenport
Transportation Research Center, Inc.
(4,203 Views)
Hi Bill,
What are you sending for the FileExportFilter parameter? Your function call should look something like this:
Call DATAFILESAVESEL("example.dat","DD8x","'[1]/Time' - '[1]/Torque'")
Note that this is going to export a DAT file with the format specified in File>>DAT Files>>Settings.  If you want to export to a text file, then change the Type of Data field to ASCII.  This will produce a file with asc extension that uses the format specified in the ASCIIREALFORMAT variable.  This works in 10.1 and 10.2 on my end.
Please post an example if I've misinterpreted what you are trying to do.
Have a great day,
Ecleamus R
Applications Engineer
(4,171 Views)
Here is what I am currently doing in 10.1:
      DATASAVETYPE="Ascii"
      ASCIIREALFORMAT="d.ddd"
      DATASAVEKEY="Block"
      ASCIISEP=";"
    Call datasavesel("C:\Temp\ASCII", "10-14")
Which kicks out a ASCII.ASC file and an ASCII.dat file with only 3 digits past the decimal.
Using this method in 10.2 I get this error: "the configured header number must be >= then channel number"
When I try to use Call DataFileSaveSel("C:\Temp\ASCI,"CSV", "10-14")  the formatting is not used.
(4,169 Views)
Try "DD8x" instead of "CSV".
Ecleamus R.
(4,165 Views)
When I try to use Call DataFileSaveSel("C:\Temp\ASCI,"dd8X", "10-14")  10.2 I also get this error: "the configured header number must be >= then channel number"
(4,166 Views)
Figured it out. The dataset I was using had more than the default maximum number of channels (ActFileHdNo). When I set this to much bigger than my data set, it works fine.
"I am so smart, S-M-R-T"~Homer Simpson
(4,142 Views)
Thanks for posting the solution. 🙂
Ecleamus R.
(4,136 Views)
