DIAdem
Find if a string contains a second string
Hallo, I need to check if a string variable contains a second string, case sensitive and not. Is there any Diadem/VBS function to do this?
Here an example of what I mean:
If StrContain("pressure","pres") Then
 ChnName = "Pressure"
 ChnUnit = "bar"
End If
(3,790 Views)
Accepted by mattia_verona
Hi mattia_verona,
You can use the InStr() command to see if a matching string is somewhere inside the larger string.  You can use the LCase() or UCase() commands to cast the larger string to lower or upper case to ignore case differences.  If you just wanted to check if the larger string started with the right matching string, you could use the Left() command.
ChName = "MYpreSSuRE"
If InStr(LCase(ChName), "pres") Then
 ChName = "Pressure"
 ChUnit = "bar"
End If
MsgBox ChName
Brad Turpin
(3,775 Views)
Thank you!
Mattia
(3,743 Views)
