DIAdem
Follow GPS data
I have time, speed, latitue and longitude.
I can draw the GPS map with latitude-y and longitude-x. However, on this 2D graph, I cannot follow the map with speed. Because this graph has no time value. X axis is longitude and Y axis is latitude.
Probably I need to make Y axis to longitude, Z axis to latitude and X axis to time. I am not sure. Is there any solution in roder to follow drawn map in Diadem display.
Edit: I use Diadem 2020.
(2,425 Views)
I have these channels. Time, Speed, Latitude, Longitude. I can draw the GPS map by assigning the latitude-x and longitude-y.
However, I want to follow the map with speed. When I assign the latitude and longitude channels, in this situation, I have no time value on the graph, hence I cannot follow the map.
Probably I need to assign time to x-axis, latitude to y-axis and longitude to z-axis. Is it possible to do this on Diadem Display?
Thank you and have a good day.
(2,448 Views)
Accepted by mmt1357
Hello mmt1357,
Please have a look at this example:
Greetings
Walter
(2,386 Views)
