DIAdem
Get channels in DIAdem 10.1
Hello
I want to iterate through all channels in the active group.
I wrote this code in DIAdem 11.1:
Dim maxLen
Dim Channel
For Each Channel in Data.Root.ActiveChannelGroup.Channels
If maxLen < Channel.Size Then
maxLen = Channel.Size
End If
Unfortunately, this script should run on a DIAdem 10.1.
DIAdem 10.1 has a problem with the Data-Object.
I only have DIAdem 11.1 and I need a Script which runs on a DIAdem 10.1.
Does anybody know how I can get all Channels from one Group in DIAdem 10.1?
(4,148 Views)
Accepted by Züger
Hi Zueger,
The Data object was introduced in DIAdem 11.0, so here's how you can write the code to loop through all the channels of the default group in DIAdem 10.x or earlier:
Dim j, maxLen, ChNum
For j = 1 TO GroupChnCount(GroupDefaultGet)
  ChNum = CNoXGet(GroupDefaultGet, j)
  maxLen = MinV(maxLen, ChnLength(ChNum))
Next ' j
Brad Turpin
DIAdem Product Support
(4,144 Views)
It works perfectly. Thank you very much!
(4,125 Views)
