DIAdem
Hotkey for copy to clipboard in REPORT
I have not found it in the help pages, but maybe there is a hotkey for File -> Clipboard hidden anywhere?
If not, is there a possibilty to customize hotkeys?
Phex
(5,164 Views)
Accepted by Phex
what exactly do you want to copy ? Most of the time the usual "ctrl + c" combination works fine.
If you need something else, you can define hotkeys(F1 .. F12) in the script part and script the action you want to be performed.
Aurelie
Applications Engineer
(5,113 Views)
Storing this piece of code to F12 hotkey does the trick::
Call Report.ActiveSheet.ExportToClipboard
Ctrl+C will only copy the Code, so it does not work for a quick and dirty transfer of the REPORT layout to another document.
Phex
(5,108 Views)
