DIAdem
How to sort a channel and move the values in other two channels accordingly?
Hello All,
I have three channels X,Y and Z. I am looking for a way to sort channel X and accordingly move the values in Y and Z channels.
I have tried  ChnMultipleSortExt but it just does it for 2 channels.
Any help is appreciated!
Thanks in Advance.
(2,854 Views)
Accepted by Kandukuri_raghavendra
Hello Kandukuri_raghavendra,
Which DIAdem version do you use?
At least since DIAdem 2015 we support your request. Here is an example.
dim oChnX, oChnYZs
set oChnX   = Data.Root.ChannelGroups(1).Channels(1)
set oChnYZs = Data.GetChannels("[1]/*")
oChnYZs.Remove(1) ' remove first channel which is the source channel
Call ChnMultipleSortExt(oChnX, oChnYZs, "Up", "UpperCase", 0)
 Greetings
Walter
(2,709 Views)
Thank you @Walter
(2,591 Views)
