DIAdem
How to switch off Datafinder
Hello
We work with a database and don't use the DataFinder service of Diadem.
How can I switch off DataFinder - in the way it doesn't launch the next time Windows starts?
James Code
(5,350 Views)
Hi James,
The DataFinder acts for all the world like a service, but by default it installs as a startup process under the user account.  Go to a DOS shell and type the folloing command:
"msconfig"
Now select the "Startup" tab and uncheck the "DataFinder" startup item.
Brad Turpin
DIAdem Product Support Engineer
(5,329 Views)
Hello James!
Brad's recommendation will only avoid the start of the DataFinder on the OS startup. The next DIAdem start will launch it and it will run even if you finish DIAdem. Unfortunately there is no setting to prevent this.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(5,323 Views)
Hi James,
To switch off the DataFinder you must do two things. The first one is like Brad's description. For the second one you must go to DIAdem>>NAVIGATOR>>Settings>>Options>>NAVIGATOR. For External Data use "Data stores" and browse to "My DIAdem 9.1". Than save this settings in the Desktop.DDD file and restart DIAdem.
Greetings
Walter
(5,315 Views)
Hi All
Thank you for your answers. The two things, switch off at system start and in DIAdem, works well.
So, I guess theres no possibility to uninstall DataFinder?
James Code
(5,247 Views)
Hello James,
You are right. That is not possible. The DataFinder is an essential component of the data management for external data in DIAdem.
Greetings
Walter
(5,210 Views)
