DIAdem
I am using PDF export, but the PDF file output is only available in Landscape.
I am using PDF export from the file meny, but the PDF page comes out in Landscape even if I have selected Portrait in Layout parameters in the settings meny. Is there a possibility to change theis?
(3,207 Views)
Hi Karlsek,
This bug is fixed in DIAdem 10.0, but you can output to PDF file programmatically in DIAdem 9.1 and set the orientation to be explicitly portrait:
PrintLeftMarg = 0.25
PrintTopMarg  = 0.5
PrintWidth    = 8
PrintOrient   = "portrait"
Call PicPDFExport("C:\Test Results.pdf")
Brad Turpin
(3,193 Views)
