09-24-2009 01:53 AM
There is a Java Web Application in our lab, which manages all the test data.
By browser IE, test data can be easily get on every computer.
Is it possible to integrate DIAdem with our system?
can DIAdem be used as an ocx?
09-24-2009 03:34 AM
Hi Chian
If you enter "DIAdem.ToCommand" in the Index of the help, you find an example in the list. You can use the IE to send commands to DIAdem or set or read variables.
Hope this helps
Winfried
09-24-2009 04:16 AM
| Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
09-24-2009 04:22 AM
This is the result I want to get. Is it possible? and how can I?
09-24-2009 04:47 AM
Hello Chian!
AFAIK is this not possible.
Matthias
09-24-2009 09:07 AM
Hi Chian,
Currently DIAdem does not make this easy. DIAdem is not built with components designed to be embedded in a browser, nor does DIAdem install a web service API that you can use to communicate with it from a browser.
If you really want all of DIAdem in your IE browser, your only option is to use a Terminal Services layer such as Citrix or the one from Microsoft. It's not a cheap solution, but DIAdem looks and works great in an IE browser pointed at a Citrix server.
Brad Turpin
09-24-2009 07:09 PM
