DIAdem
New TDM Excel Add-In does not work
I am not sure if this is the right board, but I do not find a better one.
I have installed the newest version of the TDM Excel Add-In (http://zone.ni.com/devzone/cda/epd/p/id/2944, LAST CHANGE: July 23, 2008 [ 2.0.1.14 ]). The commandbar appears in Excel, but the first two controls are only gray. And even worse, the only one that works it the About Dialog. At least I see that the version of the Add-In is matching. When I press the other two controls, nothing happens. I have removed the commandbar in Excel, uninstalled the Add-In and reinstalled it after a reboot. But nothing changed. (The version of Excel is 2000.)
Does the Add-In run successfully on somebody's computer?
Greetings,
shb
Message 1 of 10
(6,241 Views)
Accepted by shb
Sorry, I have overlooked that "The TDM Excel Add-In supports Excel 2003 and higher." I will reinstall the old version.
Message 2 of 10
(6,197 Views)
What program is used to open .tdx and .tdm data file extensions. These files are made after I log data. When I try and open the .tdm file in excel it is limited to the first 254 lines this is not enough.
Please help.
Message 3 of 10
(5,360 Views)
The current version of the TDM Excel Add-In supports up to 16,384 columns in case the Excel version you're using is 2007 or higher.
Message 4 of 10
(5,354 Views)
what is the link to it?
Message 5 of 10
(5,352 Views)
how many rows does it support?
Message 6 of 10
(5,350 Views)
The TDM Excel Add-In 3.0 or higher supports as many rows as Excel offers.
Excel 2003: 65536 rows
Excel 2007 and higher: 1048576 rows
Message 7 of 10
(5,347 Views)
Hi Tim,
the current version of the TDM Excel Add-In is available at http://zone.ni.com/devzone/cda/epd/p/id/2944
The number of rows support is ~1million in case you're using Excel 2007 or higher.
Message 8 of 10
(5,277 Views)
37.5 straight hours taking measurements every 100 seconds. Only the first 253 samples are being shown in the excel file. There are still 1097 samples that were logged but are not displayed on the sheet.
Please advice, do you have an email I could send you the files instead of posting them online?
Message 9 of 10
(5,270 Views)
Tim,
Please send the file to me at the following email address:
otmar DOT foehner AT ni DOT com
I'll get back to you after testing your file with the latest Excel TDM plugin.
    Otmar
Otmar D. Foehner
Message 10 of 10
(5,255 Views)
