DIAdem
Phase Angle Dephasing in Two time signal FFT
Pardon my English, using "dephasing".
The problem happened with FFT(Two time signal)
1st input channel is /Time
2nd input channel is /SWA (steering wheel angle,it's a Frequency Sweap)
Output channel is /Acc_Y (lateral acceleration)
The phase angle figure is as following:
The phase angle just changed the sign which is incorrect. The output channel is not ahead of the input.
Phase angle in degPhase angle in deg
Following is the time domained graph for input and output.
The output has a delay more than half cycle after  ~2.7 Hz which leads to the sign change
Red is input , green is outputRed is input , green is output
Is there any option to correct that excluding manual correction ?
(3,463 Views)
Accepted by DaiZheng
You need to unwrap the phase. Start here.
(3,431 Views)
Thanks a lot , never know this function until your answer :- )
(3,413 Views)
