DIAdem
Receving Error 383 while Querying Data finder
We have a script (vbs) that runs in  Diadem and queries a Datafinder (server edition). After adding some error handling code, we encountered the following error:
                                      Error Description: An error occurred during the search. The query may contain at least one invalid property.        Number: 383      Source: false.*
            * Now according to the message above, we can extract that there is a property or property value (of the query) that is/are wrong, but see the following line of this message please.
Once we trapped this error, we log and save the queries (in TDQ files) that were being used at the moment that the error ocurred. When we load this query files, no errors are ocurring. We've being troubleshooting this issue, but we haven't find the root cause yet. Any guidance, tip or help will be greatly appreciated.
(5,482 Views)
Does the Datafinder logfile "DataFinder.log?" contain errors that may be related.
It can be found in the Config Path of the datafinder or is part of the ZIP created with
Help->Diagnosis->CreateDiagnosoFile
(5,465 Views)
Accepted by mannypr7
Hi manny,
That sounds like a property data type issue to me.  In rare cases saving a condition from DIAdem to a *.tdq file can cause the data type of the property in that condition to change.  Can you try reducing the number of conditions to just one and determine which condition is the culprit?  Then ask yourself what operator you're using in that condition-- if it's "=" or "<>" then it supports any data type.  If it's any other condition, then it could run afoul of a string data type.  Also, you could have a datetime property that is not optimized in the DataFinder which could be considered an invalid property.
Brad Turpin
(5,416 Views)
Hi Brad,
Thanks for the response, sorry for my delay responding.  It makes a lot of sense, I am going to narrow down the queries and follow your recommendations. We are also  suspecting, that it might be bad data in one of the files that we are pulling the data from, because when we  limited the range of days in the data, the error goes away. I've set your answer as a solution since I think it is now in our side to do the investigation, but you have lead us to correct path. As always we appreciate your help, Thank you.
Manny
(5,393 Views)
AndreasK,
We have the logs, is one of the methods we use to verify our runs.
Regardless I sitll apreciate your response. Thank you for your time.
Manny
(5,390 Views)
