DIAdem
Report Active Object Identification
In a script is there a way to detect which plot in Report is selected?
The idea is for the user to select a plot and then run a script that will perform some operation using the information from that plot.
(3,305 Views)
Accepted by BrianCT
Hi Brian,
Use the selected objects function to work with currently selected objects. That link has a good example.
Matthew
Applications Engineer
(3,278 Views)
This page may also be helpful to see what methods can be performed on the selected objects.
Matthew
(3,276 Views)
