DIAdem
Script error: At least one FFT function must be selected!
I have written a script to analyse my data. I have written 2 new code sections:
1. calculations to get a Bode Plot
2. calculations to get a Waterfall diagram
My problem: If I run these scrips one by one they work as requested. But if I run them serial, I get the following error: At least one FFT function must be selected!
Does anyone have a clue on this?
Regards
Patrick
Message Edited by flupa on 03-13-2008 03:32 AM
(5,055 Views)
Hello again,
If my description was not helpfully I am sorry. I am using V 9.1. Did anyone had that fault once too?
Regards
Patrick
(5,042 Views)
If none knows that error message I should start to describe my problem:
I have a time,speed, keyphasor and a proximity sensor signal.
First Part: Bode
  1. I do a FFT with time and proximity sensor (CHNFFT1) -> Amplitudes
  2. I do a transfer calculation with time, keyphasor and proximity sensor (CHNFFT2) -> Phases
  3. Aritm. mean of speed in intervals (STATBLOCKCALC) -> Reverence Speeds
  4. Take the Amplitudes and Phases of every interval at the frequency of the first Order at the reverence speed
So far so good.
Second Part: Waterfall diagram
  1. Order Analysis in frequency domain (CHNORDAFCALC)
And now the error occurs (at this command: CHNORDAFCALC): "At least one FFT function must be selected!"
If I comment the first part, the second part works. So I really have no Idea what else to do.
Regards
Patrick
(5,036 Views)
Hello Patrick!
Do you set all global parameters before using CHNORDAFCALC? You get a list in the help.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(5,034 Views)
Yep, I think so. I recorded a macro an took the code into my script and replaced some values with variables. As I said: without the first analysis befor it works.
My settings:
  GENXBEGIN        =SpeedMin
  GENXEND          =SpeedMax
  FFTWNDFCT        ="Hanning"
  FFTWNDPARA       =10
  FFTWNDCHN        ="time"
  FFTWNDCORRECTTYP ="periodic"
  FFTCALC          =0
  FFTAMPLTYPE      ="Ampl.Peak"
  FFTAMPLEXT       ="No"
  FFTPHASE         =0
  ORDAFSIGWEIGHT   ="NoRef"
  ORDAFREVOLSTEP   = stepWidth
  ORDAFTYPE        ="Frequency"
  ORDAFFFTLENGTH   = intervalLengthFFT
  ORDAFMAXORDER    =10
  ORDAFFILTRECALC  =5
At least the last two should not be necessary if ORDAFTYPE ="Frequency".
Regards
Patrick
(5,032 Views)
Hi Patrick,
I think the easiest way for us to help would be for you to post a data set and your full script application that runs both portions of the code.  If you don't want to post it, you could alternatively send it my email address:  brad.turpin@ni.com
Brad Turpin
Product Support Engineer
(5,027 Views)
Hi all,
Brad solved my problem and I wanted to tell anyone who might have the same problem in the future how to fix that:
I just had to add the parameter:
FFTAmpl          = 1
Thank you again Brad!
Regards
Patrick
(4,999 Views)
