DIAdem
Select/Deselect a curve in a 2D plot in VIEW
Just wondering if you know a way that could select/deselect a curve to be displayed in 2D plot in VIEW from a script?  Many thanks.
Kane
(1,097 Views)
Accepted by Kane_Lok
Hello Kane,
in VIEW you can access a curve via the Curves2D collection. You can show and hide the curve using the Enable property. Use the name or index for your curve you want to hide.
View.ActiveSheet.Areas("Area : 1").DisplayObj.Curves2D.Item(1).Enable = False
AnJalpaka
(1,063 Views)
Hi AnJalpaka,
Your suggestion works perfectly.  Thanks a lot.
Kane
(1,045 Views)
