DIAdem
Simple Bar chart
Hello there, can anyone help with this issue. I am trying to create a simple bar chart with 3 inputs but they are meshed into each other. Thank you very much
(3,100 Views)
Accepted by RomanKoleno
I believe this forum is quite similar to yours:
https://forums.ni.com/t5/DIAdem/Bar-Chart-with-moret-hen-1-Channel/td-p/3152564
I hope this helps you a bit, although it appears not to be officially something available to do there is a workaround.
Kindest regards,
Matt
(3,053 Views)
