DIAdem
Sort results Datafinder by property name
Hello All,
I would like to sort my resultlist by property.name = "BENCH":
Dim oMyDataFinder, oMyQuery, MyDate, MyMin, oMyResults
Set oMyDataFinder = Navigator.ConnectDataFinder("My DataFinder")
If oMyDataFinder.Name = "My DataFinder" Then
Dim AdvancedQuery
Set  AdvancedQuery =Navigator.CreateQuery(eAdvancedQuery)
AdvancedQuery.ReturnType=eSearchFile
Call AdvancedQuery.Conditions.Add(eSearchFile,"BENCH","=", "*")
oMyDataFinder.Search(AdvancedQuery)
Set oMyResults = oMyDataFinder.Results
on error resume next
Call oMyResults.Elements.Sort("BENCH",FALSE)
msgbox(err.number&"  "&err.description)
end if
the error is "438 proprietà o metodo non supportati dall'oggetto"
oMyResults.Elements.count is 1
what is the problem?
can i sort by date ("DatatypeDate" property type)?
Yustas
(3,434 Views)
Accepted by Yustas
Hello Yustas,
your variable "oMyResults" is already an elements collection so it does not have an elements member.
Try to use this instead:
Call oMyResults.Sort("BENCH",FALSE)
Hope that helps,
Eva
(3,433 Views)
thanks Eva,
it works,
yustas
(3,426 Views)
