DIAdem
Speech Output in Diadem?
I have tried this code:
Dim oMySpeech
Set oMySpeech = CreateObject("SAPI.SpVoice")
Call oMySpeech.Speak("Hello World!")
Script runs fine, but there is no voice at all. (yes, I DID check that loudspeaker is turned on Smiley Very Happy)
I need to write a script that talks to the engineer rather than displaying messages on the screen.
What would be the best way to do this?
H.
(4,961 Views)
Hi HoBaLa,
The script works fine on my PC. It works fine either if I run it in DIAdem or save it as a VBS file and run it in Windows. Please check whether it works just in the Windows environment.
Greetings
Walter
(4,958 Views)
Thanks for the quick response.
So this seems to be a Windows restriction in my company environment. I'll check this.
Thanks for your help!
(4,954 Views)
