DIAdem
TDMS to MDF time stamp conversion error / Storage date time changes
I've been fighting this for awhile, I figured I'd throw it out there...
Lets say I have a TDMS file that has a labview time stamp channel and 2 Thermocouple channels.
I load it into DIADEM, i get this:
Perfect!  But, now lets say I want to save the TDMS as a MDF file so I can review it within Vector CANape.  I right click and save as MDF, perfect.  I fire up CANape and get this:
The year 2121, yes i am taking data on a star ship!!!  It appears to be taking the TDMS storage date/time stamp as the start point and adding the TC_Timestamp channel.
If I edit the TC_Timestamp channel to 1, 2, 3, 4, 5, 6, 7 etc.... and save as MDF, i get this:
Really close, 2012!   but what I really want is this to show from the time it was recorded which would be 10-09-2012.
The problem is every time I do the save as, the storage date time is updated to current time, then the MDF plugin appears to use that as the start point.
is there any way of stopping this from updating in DIADEM?
thanks,
Ben
Message 1 of 11
(10,063 Views)
Accepted by ben_jansky
Hi Ben,
You got it right that the MDF DataPlugin writes the Storage date/time to MDF start time that will get updated by DIAdem when writing. We are looking into this and will return to you if any progress.
As a workaround, you may want to try converting TDMS to MDF in LabVIEW with Storage VIs.
Something like the following, you can write your measurement start time to MDF file.
Hope this helps,
Mavis
Message 2 of 11
(10,007 Views)
Thanks!  this worked!
I created some fake data in a TDMS, read it in and wrote to a MDF file.
Here's my CANape plot:
Oct 9th, 2012, just as I needed.
thanks,
Ben
Message 3 of 11
(9,967 Views)
Hi All,
On October 19, 2012 the MDF DataPlugin at www.ni.com/dataplugins was updated to read the property "File.hd_start_time" and use that as the global starting date/time value for the first (Time) channel in each group.  Here's a VBScript that converts the LV elapsed seconds time channel to a DIAdem time channel and writes the corresponding "File.hd_start_time" property prior to exporting the group as a new MDF file:
UTC_Offset = 5*(3600) ' secs from GMT to measurement location
LV_DD_Offset = 60084288000 ' secs from 0 AD to 1904 AD
Call DataDelAll
Call DataFileLoad(TdmsFilePath, "TDMS")
Set Group = Data.Root.ChannelGroups(1)
Set TimeChannel = Group.Channels(1)
Call ChnLinScale(TimeChannel, TimeChannel, 1, LV_DD_Offset-UTC_Offset)
TimeChannel.Properties.Add "DisplayType", "Time"
StartTimeDBL = TimeChannel.Values(1)
StartTimeVBS = StartTimeDBL/(3600*24) - 693958
StartTime = CDate(StartTimeVBS)
Data.Root.Properties.Add "hd_start_time", StartTime
Call DataFileSave(Mdf_FilePath, "MDF")
I'm also including a VI that does something similar,
Brad Turpin
Message 4 of 11
(9,933 Views)
Hi Brad,
When I run this vi, I get two consecutive errors in the Close Data Storage block, and it does not write the mdf file. I've attached a screenshot. Do you know what might be going wrong?
Thanks -
Message 5 of 11
(9,510 Views)
Hi aoehlerking,
Where is this error actually occuring in your code? The trick will be finding the point of failure and checking to ensure the object reference given to that point is still valid.
James W.
Applications Engineer
Message 6 of 11
(9,495 Views)
Hi aeo,
Your attached conversion error PNG file appears to be empty.  The VI ran correctly on my computer, so I'm quite curious what the error is on yours.
Brad Turpin
Message 7 of 11
(9,490 Views)
That's odd - when I click on the .PNG link, it shows the screenshot of the error that I'm getting...in any case, the error window reads as:
Error - 2553 occurred at Close Data Storage
Possible reasons: The object refnum is invalid. The node that returned this refnum might have encountered an error and did not return a valid refnum. The storage this refnum refers to might have closed before the call executed.
Could this point to a race condition in the .vi?  I did not make any modifications - just downloaded, ran in LV 2012, selected a .tdms file, then selected an .mdf file to save to.
Message 8 of 11
(9,480 Views)
Hi aoe,
I get the same error you do if I leave the "Group to Export" control set to "3" and select a TDMS file with fewer than 3 Groups in it.  If I change the "Group to Export" control to "1" the VI performs perfectly in LV 2012.
Brad Turpin
Message 9 of 11
(9,476 Views)
Ahh, yes that is clear now, thanks Brad. I should have tried fiddling with that before.
Perhaps diverging from the main point of this thread, but my new error is that LabView is unable to recognize my data-plugin for .mdf files. The error is:
Error -2564 occurred at Close Data Storage
Possible reason(s):
LabVIEW: The software installed on this computer does not support the file format you requested. The Storage/DataPlugin VIs access files through plug-in libraries LabVIEW and DIAdem install.
I have installed both mdf plugins (3.0 and 4.0) from this page and restarted the computer multiple times: http://zone.ni.com/devzone/cda/epd/p/id/452. However, after double clicking on the 'Open Data Storage' block, it still does not show MDF as a DataPlugin option.
Do I need to adjust some other Labview setting to get it to recognize the installed plugins?
Thanks -
Austin
Message 10 of 11
(9,470 Views)
