DIAdem
View panel channel color display
Does anyone know of a way to change the default channel colors (and other properties like line width) in the View panel?
i.e. 1st channel is red, 2nd channel is green, etc.
I do a lot of screen shots from the view panel and the default colors are not always best for viewing.
Message 1 of 11
(5,397 Views)
You can change it during runtime by right clicking on the legend or via property nodes
https://www.ni.com/docs/en-US/bundle/labview/page/customizing-graphs-and-charts.html
See Color—Displays the color picker so you can select the color of the plot.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 2 of 11
(5,393 Views)
Yes, thank you....but I want to change the default settings.
Message 3 of 11
(5,388 Views)
Is this code or an exe?
Do you want the colors to be changed during runtime?
Do you want to store the last set colors to a file so that on the next run those are the colors?
ALE Consultants
Message 4 of 11
(5,386 Views)
I want to open diadem, load a .tdm, drag channels into the view pane with specific default colors - ch. 2 want blue instead of green, for example.
Message 5 of 11
(5,374 Views)
I apologize, the above info I posted is incorrect.
Any luck modifying the TDV file?
ALE Consultants
Message 6 of 11
(5,367 Views)
In general you can modify the default settings for the color in any dialog box. But you could create a script that creates you layout or you define a "OnDrop" event.
For the ondrop event you find information in the DIAdem help: https://www.ni.com/docs/en-US/bundle/diadem/page/scriptview/properties/view_property_ondrop_itoevent...
If you want to create the layout by script the best starting point is to press Ctrl+Shift+C in the dialog box of the curves. Then open DIAdem SCRIPT and paste the code that was generated.
Hope that helps
Winfried
Message 7 of 11
(5,362 Views)
There was an idea exchange post about default VIEW configuration some time ago.
Looks like this has not been implemented yet, so feel free to give Kudos for that 😉
Christian
CLA, CTA, CLED
Message 8 of 11
(5,358 Views)
Accepted by KenM_22056
As a workaround you can define your colors in DIAem: Settings --> DIAdem Settings --> Colors
Then use this example script to assign these colors in the same order to all 2D axis system curves in the current view sheet:
dim i,oArea
for each oArea in View.ActiveSheet.Areas
	if StrComp(oArea.DisplayObjType, "CurveChart2D") = 0 then
		for i=1 to oArea.DisplayObj.Curves2D.Count
			oArea.DisplayObj.Curves2D(i).Color = "other colors"
			oArea.DisplayObj.Curves2D(i).ColorRGB = UserDefColors(((i-1) mod 16)+1)
		next
	end if
next
call view.Refresh()
Christian
CLA, CTA, CLED
Message 9 of 11
(5,353 Views)
Thank you Christian...this works perfectly.
Message 10 of 11
(5,339 Views)
