DIAdem
add column
Hi klifoufou,
I see that you have a VBScript which creates 8 empty channels in the Data Portal in a new Group and then completely creates a Table from scratch that displays the values of those 8 channels, one for each column.  The problem is that the 8 channels have no channel values.  You need to copy the properties you want to display in the table from the source channels into the values of these new 8 channels.  I offered to help with this earlier, but I can't give you working code without your starting data set.  The command to do the value assigning is ChV(row, channel), and the command to read the source channel property value is ChnPropValGet(channel, propname).  So it looks something like this, only in a loop to create the 8 columnsx100 rows in the multipage table.
ChV(i, Ch1) = ChnPropValGet(SourceCh, "minimum")
Brad Turpin
DIAdem Product Support Engineer
Message 11 of 27
(3,436 Views)
You will find the file of my tests,  you will find the .dat to load and the both of the macros that i created.
I created a macro for the title of the columns which called "table_test2 .vbs" and after I saved the obtain graph « Table_test2.TDR » and I called in the macro of column « 8 colonnes .vbs »
I know that it's not a solution because in this case the number of lines is always the same, and in my case I have to do a macro which depend of the number of channels
(exemple: for 10 channels I have to do a table with 10 channels not more and not less)
Furthermore, I have the problem of the size of datas which is not enough big when I add  D2TabVariable(2)="@ChnComment(d2tabrow)@" for the second column, and  of the maximum time and the minimum time too.
I hope that you understand my problems and you can help me.
Thanks a lot
Message 12 of 27
(3,432 Views)
Accepted by topic author klifoufou
Hi klifoufou,
I altered your 8 colonne script to build a multipage table I think you will like:
OPTION EXPLICIT
Dim i, iMax, voie, Filt, NumTableRows, FirstRow, LastRow
For voie = 1 to ChnNoMax
  Select Case UCase(Right(CN(voie), 1))
    case "0" : Filt = "Unfiltered"
    case "P" : Filt = "Native data"
    case "A" : Filt = "CFC1000"
    case "B" : Filt = "CFC600"
    case "C" : Filt = "CFC180"
    case "D" : Filt = "CFC60"
    case "X" : Filt = "Without Filter"
  end select
  Call ChnPropValSet(voie, "Filter", Filt)
next ' voie
NumTableRows = 20
iMax = ChnNoMax/NumTableRows
IF CLng(iMax) < CDbl(iMax) THEN iMax = CLng(iMax + 1)
Call PicDelete()  'clear DIAdem Graph
Call WndShow("REPORT")
FOR i = 1 TO iMax
  IF i = 1 THEN
    Call GraphSheetInfos()
    Call GraphSheetNGet(GraphSheetCount)
    Call GraphSheetRename(GraphSheetName, "Table " & i)
  ELSE
    Call GraphSheetNew("Table " & i)
  END IF
  FirstRow = 1 + (i-1)*NumTableRows
  LastRow  = i*NumTableRows
  IF LastRow > ChnNoMax THEN LastRow = ChnNoMax
  Call GraphSheetRefSet("Table " & i)
  Call CreateTable("PropTable", FirstRow, LastRow, 1)
  Call PicUpdate
NEXT ' i
Sub CreateTable(TableName, RowStart, RowStop, RowStep)
  Call GraphObjNew("2D-Table", TableName)
  Call GRAPHObjOpen(TableName)
    D2TabBegin = RowStart
    D2TabEnd = RowStop
    D2TabNoDist = RowStep
    D2TabAutoScalTyp = "fixed"
    D2TabTop         = 1
    D2TabBottom      = 1
    D2TabLeft        = 1
    D2TabRight       = 1
    D2TabXDoubleLine = 1
    D2TabYDoubleLine = 1
    D2TabTxtAutoScal = 1
    D2TabGrid(1)     = 1
    D2TabGrid(2)     = 1
    D2TabNumAutoScal = 0
  '''************************Nom****************************
          D2TabHeaderTxt(1,1)= "Nom"
          D2TabTxtType(1) = "column defined headline"
          D2TabDataType(1)="Expression"
          D2TabVariable(1)="@ChnName(D2TabBegin-1+d2tabrow)@"
          D2TabRelWidth(1)= 1.0
          D2TabNumSize(1) = 2.35
  '************************ Description *******'
          D2TabHeaderTxt(2,1)= "Description"
          D2TabTxtType(2) = "column defined headline"
          D2TabDataType(2)="Expression"
          D2TabVariable(2)="@ChnComment(D2TabBegin-1+d2tabrow)@"
          D2TabRelWidth(2)= 1.5
          D2TabNumSize(2) = 2.35
  '************************ Filtrage ***************************
          D2TabHeaderTxt(3,1)= "Filtrage"
          D2TabTxtType(3) = "column defined headline"
          D2TabDataType(3)="Expression"
          D2TabVariable(3)="@@ChnPropValGet(D2TabBegin-1+d2tabrow, ""Filter"")@@"
          D2TabRelWidth(3)= 1.0
          D2TabNumSize(3) = 2.35
  '''''**************** Minimum *****
          D2TabHeaderTxt(4,1)= "Minimum"
          D2TabTxtType(4) = "column defined headline"
          D2TabDataType(4)="Expression"
          D2TabVariable(4)= "@str(CMin(D2TabBegin-1+d2tabrow), ""d.dd"")@"
          D2TabRelWidth(4)= 0.5
          D2TabNumSize(4) = 2.35
  '**********************Temps de minimum ****
          D2TabHeaderTxt(5,1)= "Temps de minimum"
          D2TabTxtType(5) = "column defined headline"
          D2TabDataType(5)="Expression"
          D2TabVariable(5)=""
          D2TabRelWidth(5)= 1.0
          D2TabNumSize(5) = 2.35
  '********************** Maximum ***********
          D2TabHeaderTxt(6,1)= "Maximum"
          D2TabTxtType(6) = "column defined headline"
          D2TabDataType(6)="Expression"
          D2TabVariable(6)="@str(CMax(D2TabBegin-1+d2tabrow), ""d.dd"")@"
          D2TabRelWidth(6)= 0.5
          D2TabNumSize(6) = 2.35
  '*********************** Temps de maximum *************'
          D2TabHeaderTxt(7,1)= "Temps de maximum"
          D2TabTxtType(7) = "column defined headline"
          D2TabDataType(7)="Expression"
          D2TabVariable(7)=""
          D2TabRelWidth(7)= 1.0
          D2TabNumSize(7) = 2.35
  '************************* Unité ********************''''
          D2TabHeaderTxt(8,1)= "Unité"
          D2TabTxtType(8) = "column defined headline"
          D2TabDataType(8)="Expression"
          D2TabVariable(8)="@Cd(D2TabBegin-1+d2tabrow)@"
          D2TabRelWidth(8)= 0.4
          D2TabNumSize(8) = 2.35
  Call GraphObjClose(TableName)
End Sub ' CreateTable()
Brad Turpin
Message 13 of 27
(3,422 Views)
Thank you very much for your help. That's it the idea which I want to develop but I obtain more than 20 tables and the informations appear only on the five first tables.
Could you give me an idea to appear want I want?
One more time, thank you for the help
Message 14 of 27
(3,409 Views)
Hi Brad,
Thank you very much.
 it works perfectly,   I just changed the loop level for the  multi-page
Many thanks for your help   Smiley Happy
Message 15 of 27
(3,398 Views)
Today I come to you in order to have your help about a problem.
When the program calculates the number of channels (so the number of page), I have a problem on the last page because when I don't have less channels to complite the all the line of the table, the size of the cases are bigger than the others on the others pages. And when I have only one channel on the last page, this case appear in the middle of the page.
The problem is that I want to keep the same size of cases for all situations.
you can see the difference between the two tables in Attachments below.
Thank you for your help.
Message 16 of 27
(3,383 Views)
Hi Klifoufou,
Here's a new version of the script I posted before, with changes to scale the size of the last page's table and table header to match the row height and header height of the previous pages:
OPTION EXPLICIT
Dim i, iMax, voie, Filt, NumTableRows, FirstRow, LastRow, RowRatio
  end select
next ' voie
NumTableRows = 20
FOR i = 1 TO iMax
  IF i = 1 THEN
  ELSE
  END IF
  RowRatio = (LastRow-FirstRow+1)/NumTableRows
  Call CreateTable("PropTable", FirstRow, LastRow, 1, RowRatio)
  Call PicUpdate
NEXT ' i
Sub CreateTable(TableName, RowStart, RowStop, RowStep, RowRatio)
  Dim TblRange, HdrRange, RowRange, NewRowRange, NewTblRange
    D2TabEnd = RowStop
    D2TabTop         = 1
    D2TabBottom      = 1
    D2TabLeft        = 1
    D2TabRight       = 1
    D2TabGrid(1)     = 1
    D2TabGrid(2)     = 1
  '************************ Description *****************
  '''''**************** Minimum *************************
  '**********************Temps de minimum ***************
          D2TabVariable(5)=""
  '********************** Maximum **********************
          D2TabVariable(7)=""
  '************************* Unité **********************
  '======================= Scale the Table ===============
      TblRange = 100 - D2TabTop - D2TabBottom
      HdrRange = TblRange*D2TabTxtField/100
      RowRange = TblRange - HdrRange
      NewRowRange = RowRange*RowRatio
      NewTblRange = HdrRange + NewRowRange
      D2TabBottom = 100 - D2TabTop - NewTblRange
      D2TabTxtField = 100*HdrRange/NewTblRange
Brad Turpin
Message 17 of 27
(3,371 Views)
Hi Brad,
 it works perfectly
Message 18 of 27
(3,356 Views)
Hello Brad,
 I come to you today hoping you can help me even this time.
 Always the same problem in the table, but this time, I find that difficult if I compare it to the last time.
 This time I try to make a page that summarizes the results of the accident: HIC (36/15), RESULTING Acceeleration, cumulative 3ms, NIC, VC, ThCC .... And which can be used for any case. In a first time , I will interested to the driver (AVG) and passenger (AVD)
 you can find below an example that summarizes what I'm trying to do
I hope that you understand what I want to do.
Thank you
Message 19 of 27
(3,337 Views)
Hi klifoufou,
What we can do in a DIAdem 2011 table is conditionally color the text or change its other text properties such as bold or font.  The method to do this is very flexible, but not obvious at all.  You have to create a VBScript that analyzes the value of a cell and assigns the appropriate coloring, font, etc.  Then you have to make that VBScript a global user command.  Then you have to edit the table configuration to call that VBScript when redrawing the table cells in REPORT.
Here's an example,
Brad Turpin
National Instrument
Message 20 of 27
(3,334 Views)
