DIAdem
add column
hi,
I did not understand why you talk about color.
the example is in order to see the table of contents
Message 21 of 27
(1,680 Views)
Hi Klifoufou,
I talked about color in the 2D table, because everything else in the table is straightforward.  You're already reporting information in tables.  What is different about this summary table from the tables you have now, that it's not clear how to display this information?  Where is the information to display-- is it stored in Group or Channel properties in the Data Portal?
Brad Turpin
DIAdem Product Support
Message 22 of 27
(1,667 Views)
Hi Brad,
Tthank you for your help.
 I try to do a page (in the form of a table) that summarizes the results of the accident : HIC (36/15), RESULTING Acceeleration, cumulative 3ms, NIC, VC, ThCC ...
You find in the attached. dat file to load the program and Which I'm trying to write.
I started by the HIC. The idea is to select the channels for the head and display it in a table with his caracterestique: HIC values ​​/ HIC36/HIC15, type of mannequin, Manquin position. (The shape of the table is almost the same as the example I gave you yesterday)
For the moment I succeeded to make the selection of channels and calculate the HIC but just display the result in a message.
I hope that explains it better
thanks
Message 23 of 27
(1,665 Views)
I told you that I started with the calculation of HIC, but I just figured that I must calculate the resultant acceleration before
Message 24 of 27
(1,659 Views)
Do you have any ideas to help me please , I'm stuck I can not advance in the program
Message 25 of 27
(1,648 Views)
help me please, I calculated all the criteria important but I can not put them in a table as it is asking
please help me
Message 26 of 27
(1,636 Views)
Hello klifoufou,
Please check my response in the HIC thread here: HIC thread
     Otmar
Otmar D. Foehner
Message 27 of 27
(1,632 Views)
