09-13-2010 07:24 AM
Hi all,
According to DIadem Help, chd determines The first index specifies the channel row, the second index specifies the channel by the channel name or by the channel number.
for eg : ChnFind("Ch(2) > 300" ,250) searches from row 250 for a value > 300 and gives the row number in first column. Suppose answer is 4225 meaning in row 4225 we can find chnvalue > 300 in channel 2.
But if i want to retrieve the 4th column value(instead of 1st column) as result depending on the 2nd channel condition, which command i can use?
For more detail,
I have attached a dat file and an incomplete script.
All the details i have mentioned in the script only as comments.
Solved! Go to Solution.
09-13-2010 09:52 AM
Hi There,
well, you already now the Command: its Chd or Chdx (faster).
Here I have your script:
Option Explicit 'Forces the explicit declaration of all the variables in a script.
Dim Row, FilePath
Dim intMyResult
Call Data.Root.Clear
Call DataFileLoad(AutoActPath&"C100225-1 CHEST.DAT","DAT","Load") '... DataFilename,FileImportFilter,ImportAction
'differentiate these two channels
Call ChnDifferentiate("[1]/000000000000TI00","[1]/000000000000DS0D","/DifferentiatedX","/DifferentiatedY") '... XW,Y,E,E
'search what is the value of differentiated Y channel at 300 mm in channel 2.
intMyResult = ChnFind("Ch(""C100225-1 CHEST/000000000000DS0D"")>300",250)
Call MsgBox (ChDx(intMyResult,4))
When you run this code, you will get the value in Channel 4 in Row 6225. This only works if you want to get the same row (obviously 😉 )
Hope that helps, RMathews
