DIAdem
chnFind- To find the chnnel value
Hi all,
According to DIadem Help, chd determines The first index specifies the channel row, the second index specifies the channel by the channel name or by the channel number.
for eg : ChnFind("Ch(2) > 300" ,250) searches from row 250 for a value > 300 and gives the row number in first column. Suppose answer is 4225 meaning in row 4225 we can find chnvalue > 300 in channel 2.
But if i want to retrieve the 4th column value(instead of 1st column) as result depending on the 2nd channel condition, which command i can use?
For more detail,
I have attached a dat file and an incomplete script.
All the details i have mentioned in the script only as comments.
(4,292 Views)
Accepted by topic author Rash.patel
Hi There,
well, you already now the Command: its Chd or Chdx (faster).
 Here I have your script:
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Dim Row, FilePath
Dim intMyResult
Call Data.Root.Clear
Call DataFileLoad(AutoActPath&"C100225-1 CHEST.DAT","DAT","Load") '... DataFilename,FileImportFilter,ImportAction
'differentiate these two channels
Call ChnDifferentiate("[1]/000000000000TI00","[1]/000000000000DS0D","/DifferentiatedX","/DifferentiatedY") '... XW,Y,E,E
'search what is the value of differentiated Y channel at 300 mm in channel 2.
intMyResult = ChnFind("Ch(""C100225-1 CHEST/000000000000DS0D"")>300",250)
Call MsgBox (ChDx(intMyResult,4))
 When you run this code, you will get the value in Channel 4 in Row 6225. This only works if you want to get the same row (obviously 😉 )
Hope that helps, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(4,285 Views)
