DIAdem
design mathematical calculation in script on each element of array.
Hi all,
I am trying to write the VB script in which i want to do different custom mathematical operation on each element of any specific channel data. For example for every element i want to find average of next two index data and two before and then after based on results, there is further computation.
It will be great help if any one can guide me in performing operation on array elements inside diadem script, as we can do in labview using index in array. There is predefined mathematics and statistics tool in Diadem under analysis tab. But i want to design for my custom mathematical operation.
Thnks
HS
(4,877 Views)
Hi HS,
What version of DIAdem are you using?  The data access functions were improved in the latest DIAdem 11 version.
Brad Turpin
(4,864 Views)
Hi Brad,
I am using DIAdem 10.2. I m looking for help in designing custom mathematical operation as i had explained in my previous post..can we do in this version ? and please help me designing so.
HS
(4,856 Views)
Accepted by H_SH
Hi HS,
Here is a DIAdem 10.2 version of what I understand you to be asking for:
Window = 2
Denom = 2*Window+1
Threshold = 10
ChNum = CNo("[1]/Speed")
FOR i = 1+Window TO ChnLength(ChNum)-Window
  Sum = 0
  FOR j = i-Window TO i+Window
  Sum = Sum + ChDX(j, ChNum)
  NEXT ' j
  Ave = Sum/Denom
  IF Ave > Threshold THEN
    ' do contingent action
  END IF
NEXT ' i
Brad Turpin
(4,838 Views)
Hi Brad,
Thanks alot for your support and help...
Regards
HS
(4,833 Views)
