DIAdem
isf plugin
I try to use the isf plugin for Diadem, but the data isn't converted correctly. Maybe someone can help me out here. Im not sure about channels 1 and 3. But for channel 2 it seems like all negative voltages are just cut off.
(524 Views)
After some time I had to return to this problem. Since the plugin is not working correctly, I wrote my own plugin. If anyone has a problem using the official plugin, here is my version. It should work for all oscilloscopes.
(112 Views)
