DIAdem
load dataplugin via script
Hi there,
how can i load a dataplugin (*.uri) via script? Can I check the current plug-ins, if the plug-in is already loaded?
Greetings,
Martin
(5,378 Views)
Accepted by MartinKozlowski
Hi Martin
The following will let you know what the current revision of a data pluggin is.
The second function will update the data plugin if it requires it.
Enjoy!
Paul
'  Gets the version of a dataplugin
function GetDatapluginVersion(strDatapluginName)
  Dim oMyDataPlugin
  Set oMyDataPlugin = Navigator.Settings.RegisteredDataPlugins(strDatapluginName)
  GetDatapluginVersion = oMyDataPlugin.Version
  'Call MsgBoxDisp(oMyDataPlugin.Version)
end function
sub CheckUpdateAOP5
dim strAOP5CurrentVersion,strAOP5LatestVersion
dim MyVar
dim path2AOP5: Path2AOP5 = "Yours to fill in"
strAOP5CurrentVersion =GetDatapluginVersion("AOP5")
strAOP5LatestVersion = "11.0.1f5081"
if strAOP5CurrentVersion = strAOP5LatestVersion then
'msgbox("AOP5 Latest version:"&strAOP5LatestVersion & " equals " &strAOP5CurrentVersion )
else
MyVar = MsgBox("AOP5 Dataplugin requires updating Update Now?", vbYesNo + vbQuestion, "DIAdem")
Select Case MyVar
Case vbYes
Call ExtProgram( Path2AOP5 )
End Select
end if
end sub
(5,371 Views)
thank you very much 🙂
(5,363 Views)
