DIAdem
print decimal number
I am trying to print decimal number but i always got the decimal number (between -1 to 1) witout "0" or "-0"
Dim num:num= 0.235
Msgbox(num)
its print: ".235"
thanks
(5,342 Views)
Accepted by OzShimon
Hello OzShimon,
That's odd, I just tried your code and get this result:
I did notice that this behavior can be changed in the "Regions and Language" configuration of Windows. In Windows 7 it's this dialog:
If I change the settings in this dialog to no leading zeros, the result is the same as you described.
Can you check your Windows settings and confirm that yours looks the same as mine?
      Otmar
Otmar D. Foehner
(5,331 Views)
Thanks it's working!!
(5,320 Views)
