DIAdem
resample
Hi!,
I want to resample two signals,  one of this, the time and the other the speed. The channels are 1.091.064 values (lenght) and I want to reduce this channels to 60.000 values. What can I do?
THank you.
Sara
(4,006 Views)
Accepted by s.g.m.
Hi Sara,
I assume you want to do the reduction interactively. First of all select DIAdem ANALYSIS. To create a new time channel choose Channel functions >> Generate Numeric Channel and enter the Start value, the End value and 60.000 for the number of values. To resample your existing y channel choose Curve Fitting >> Linear Mapping and enter your "old" x and y channel and your new time channel (LinearGenerated) as the interpolation channel.
Ralf
(4,005 Views)
Thanks!!
(4,003 Views)
