DIAdem
reverse waveform channel values
Hi everyone,
Does anyone know how I can reverse the values of a waveform channel in Diadem? ( practically perform the Reverse 1D Array function of Labview).
Cheers
(7,035 Views)
Accepted by Saloutios
Hi Saloutios,
So let's say your starting waveform channel has waveform properties that define the X axis to run from 0 to 0.999 with a step with of 0.001, for a total of 1000 values.  Are you asking how to redefine the waveform properties so that the X axis instead starts at 0.999 and descends down to 0 with a step width of -0.001?  If that's what you want, just redefine the waveform properties like this:
Set Channel = Data.Root.ChannelGroups(1).Channels(3)
StartValue = Channel.Properties("wf_start_offset").Value
Increment = Channel.Properties("wf_increment").Value
Length = Channel.Properties("length").Value
EndValue = StartValue + (Length-1)*Increment
Channel.Properties("wf_start_offset").Value = EndValue
Channel.Properties("wf_increment").Value = -Increment
Brad Turpin
(7,025 Views)
Hi Brad,
Thanks for the reply. Yes, that's what I am trying to do. Just to make it clear, I dont want just the X axis to change order but also the Y values, eg. if my channel values are:
time X: [0, 0,001, 0,002, 0,003, ..., 0,999]
       Y: [8, 5, 7, 2, ..., 9]
I would like the get a channel that looks like:
time X: [0,999, ..., 0,003, 0,002, 0,001, 0]
       Y: [9, ... , 2, 7, 5, 8]
When I view my channel at the VIEW tab, the x-axis should start at 0,999 and descent as you move to the right to 0.
I tried to run your script but I ran into an error about an undefined variable ''Channel''. I am sorry but I do not know VBScripting so if you could incoporate a dialog box prompting which channels I would like to reverse, I would be grateful.
Cheers
(7,020 Views)
Hi Saloutios,
Good news and bad news.  You can invert the array order of the Y values by using the ChnInvert() command.  You can also change the display of the X axis in REPORT to "Inverted" instead of linear and get the desired display on the X axis WITHOUT any waveform property changes or the ChnInvert() command.  But you're stuck in VIEW.  No matter how you order the X and Y values, VIEW will always plot increasing X values from left to right.
Why DO you want the higher X value on the left of the VIEW graph's X axis?
Brad Turpin
(7,014 Views)
Hi Brad,
Thanks for the quick reply. Sorry, my mistake, wanted to write REPORT, not VIEW tab. Is it easy for you to provide a final script that could undertake the task with a dialog box asking which channels to process? Unfortunately I cannot perform changes at the script you provided.
Cheers
(7,012 Views)
Hi Saloutios,
Well then you're all set.  You don't need to change the channel values or the waveform properties.  Just leave everything the way it is except change the X axis scaling type from "Linear" to "Inverted" in the Curve and Axis Definition, then save that setting change to the *.TDR file.
No programming required,
Brad Turpin
(7,010 Views)
Thanks a lot Brad!
(6,998 Views)
